Cart 0
Lighthouse V2 base station
SKU: 800000002
$240.00
The Lighthouse V2 base station is used to enable on-board positioning on the Crazyflie together with the Lighthouse positioning deck. It comes with a power adapter with detachable plugs for internationalization.
Features
  • Enables on-board positioning for the Crazyflie
  • 1/4' standard attachment
  • 3 meter power chord
  • Wall mount
Specifications
  • Max range: 5 meters
  • Contains SteamVR Base Station 2.0 (V003450-00-A)
Mechanical specifications
  • Basestation
    • 1/4' mounting screw in bottom and back of the base station
    • Weight: 266g
    • Size (WxHxD): 80x74x63mm
  • Power adapter
    • 3 meter chord
    • Power plug adapters for EU/US/UK/JP/AU
    • Weight: 240g
    • Size (WxHxD): 40x64x34mm (without cable and plug)
  • Wall mount
    • Height: 10 cm
    • Base diameter: 5,7 cm
    • Weight: 44 g
    Package contents
    • 1 x SteamVR Base Station 2.0
    • 1 x 12V DC adapter with 3 meter cord (including adapters for US/EU/JP/UK/AU)
    • 1 x Wall mount with 1/4' mounting screw including screws for attachment to the wall
    Country of origin: USA
    More from this collection
