Cart 0
Crazyflie® WiFi Camera Deck
SKU: 100097714
$85.00
Add wireless video streaming to your Crazyflie and start experimenting with computer vision!
The Crazyflie® WiFi Camera Deck opens up new possibilities for computer vision, image processing and autonomous flight research. Featuring an HD camera and a Wi-Fi 6 module, it streams camera images to an external computer, where you can run your own processing and analysis.
Designed for researchers, developers and educators, the WiFi Camera Deck provides a starting point for a wide range of computer vision and robotics experiments, including:
  • Object detection, recognition and tracking
  • QR code and barcode detection
  • Visual navigation and localization
  • Monocular depth estimation
  • Vision-based control and autonomous flight
  • Combining visual information with Crazyflie's onboard sensors and positioning systems
The deck is intended as an experimentation platform rather than a dedicated first-person-view (FPV) camera.
Features
  • Camera: 1280 × 720 at up to 30 fps, or 640 × 360 at up to 60 fps
  • Image sensor: Novatek NT99141 CMOS
  • Field of view: Approx. 115° (diagonal)
  • Rolling shutter
  • Wireless video streaming: MJPEG over Wi-Fi
  • Wi-Fi 6 connectivity: Powered by a Qualcomm QCC748M wireless module
  • Programmable processor: 32-bit RISC-V processor running at up to 325 MHz
  • Flexible mounting: Can be mounted on top of or underneath the Crazyflie
  • Compatibility: Works with the Crazyflie 2.1+ and Crazyflie 2.1 Brushless
  • Weight: 5g
  • Dimensions: 22 x 53 mm
Package contents
  • 1 x Crazyflie Wifi Camera Deck
Availability
The Crazyflie WiFi Camera Deck is expected to be available in early 2027.
Sign up to be notified when the product becomes available!
This is a preliminary product description. Detailed specifications, documentation and performance characteristics will be published closer to release. Features and specifications may be subject to change.
More from this collection
