Qi 1.2 wireless charging deck
SKU: 114991675
$30.00
Need to charge your Crazyflie 2.X without connecting the micro-USB cable? Then the Qi 1.2 charging deck is a great option. It supports the same Qi standard as mobile phones up to 1A at 5V.
Features
- Compatible with the WPC v1.2 Qi standard
- Automatic detection of expansion board using 1-wire memory
Specifications
- Designed for mounting under the Crazyflie
- 1-wire memory for automatic expansion board detection
- Supports the Qi wireless charging standard (WPC v1.2 Qi)
- Can supply up to 1A at 5V
- Based on the TI BQ51013B
- Weight: 5.0g
- Size (WxHxD): 30x30x5mm
Compatibility
Package contents
- 1 x Qi 1.2 inductive charging deck
