Cart 0
Crazyradio 2.0
Crazyradio 2.0
SKU: 114993492
$43.00
The Crazyradio 2.0 enables the Crazyflie and Bolt to easily connect to a computer for more advanced use-cases. Using our Python library it's quick to create a low latency link which can be used for controls as well as logging and setting parameters in real-time. The dongle is delivered with a USB bootloader, where you can easily drag and drop your firmware.
 Although designed for our Crazyflie products, the USB dongle can be used for a range of applications since custom firmware can be flashed on it.
Note: Crazyradio 2.0 is not compatible with custom firmware made for the Crazyradio PA nRF24 MCU (for instance various security firmware projects) since it's based on a newer nRF52 chipset.
Features
  • Radio power amplifier giving 20dBm output power
  • Open source firmware
  • Firmware upgrade via USB
  • Debug connector
  • Low latency
Package contents
  • 1 x Crazyradio 2.0
  • 1 x Duck antenna 2dBi
Country of origin: Vietnam
More from this collection
