Cart 0
Crazyflie 2.1 Brushless charging dock
SKU: 900000063
$40.00
This product is in early access stage. It means that while the hardware is working and tested, the software is still pretty much work in progress. For more information see the early access description page.
Make sure your Crazyflie 2.1 Brushless keeps charging while on the ground with this charging dock.
Note: The charger is only compatible with the Crazyflie 2.1 Brushless, not the Crazyflie 2.1+ or other brushed versions of the Crazyflie.
Warning: Please make sure there are no pins sticking out underneath the Crazyflie 2.1 Brushless. Either attach the pin headers from above or cover the pins at the bottom (the battery holder deck is suitable for this). If there are pins sticking out at the bottom there is a risk of damaging your attached decks.
Features
Mechanical specifications
  • 3D printed charging pad
    • Matte black PET
    • Weight: 86 g
    • Diameter: 125 mm
    • Height: 27 mm
  • 12 V power adapter
    • 3 meter chord
    • Power plug adapters for EU/US/UK/JP/AU
    • Weight: 240 g
    • Size (WxHxD): 40x64x34 mm (without cable and plug)
Package contents:
  • 1x Crazyflie 2.1 Brushless charging dock
  • 1 x Power adapter
Share this Product
More from this collection
