250mAh LiPo battery
SKU: 114993561
Country of origin: China
$6.50
Make sure to get the maximum amount of flight-time from your Crazyflie 2.X using this spare battery.
Features
- Operating Temperature: 0~45°C (Charging) / 0~60°C (Discharging)
- Connector: Molex 51005-2P (Pin 1 positive)
Electrical specification
- Capacity: 250mAh
- Nominal voltage: 3.7 V (1 Cell)
- Max discharge: 15C
- Charge: 2C
Mechanical specifications
- Weight: 7.1g
- Size (WxHxD): 20x7x30mm (not including cable)
Package Contents
- 1 x 250mAh LiPo battery
Caution
Using a battery under direct sunlight may cause overheating, which could result in invalidation or fire. Battery should be charged with proper charger, in compliance with correct operation instruction. Never charge the battery unattended!
NOTICE: Due to new regulations, shipping more than two spare batteries per Crazyflie implies a higher shipping fee for special handling. It will be calculated in your cart.
