          250mAh LiPo battery including 500mA USB charger
          SKU: 900000066
Country of origin: China
              $10.50
          NOTICE: Due to new regulations we're limited to only shipping spare batteries together with Crazyflie 2.X, and even then the limit is 2 spare batteries per Crazyflie 2.X.
Make sure to get the maximum amount of flight-time from your Crazyflie 2.X using this spare battery and charger.
250mAh LiPo battery
Features
- Operating Temperature: 0~45°C (Charging) / 0~60°C (Discharging)
- Connector: Molex 51005-2P (Pin 1 positive)
Electrical specification
- Capacity: 250mAh
- Nominal voltage: 3.7 V (1 Cell)
- Max discharge: 15C
- Charge: 2C
Mechanical specifications
- Weight: 7.1g
- Size (WxHxD): 20x7x30mm (not including cable)
LiPo battery charger
Features
- 500mA single-cell Li-Po battery charger
- Charging indicator
- Connection points for chaining of multiple chargers
For more details about the battery charger, please see the product page on our web.
Package Contents
- 1 x LiPo battery charger
- 1 x 250mAh LiPo battery
Caution
Using a battery under direct sunlight may cause overheating, which could result in invalidation or fire. Battery should be charged with proper charger, in compliance with correct operation instruction. Never charge the battery unattended!
