STEM ranging bundle
SKU: 900000033
$385.00
$405.00
With the STEM ranging bundle you get everything you need for scripting and learning how to operate a robot in 3 dimensions and react to objects around it. We supply an easy to use Python API where you can use commands like "move forward 1 meter", program paths the Crazyflie will follow and "measure distance to the right". You will also get access to the full logging framework where you easily can read telemetry and measurement data.
Bundle contents:
- 1 x Flow deck v2
- 1 x Multi-ranger deck
- 1 x Crazyflie 2.1
- 1 x Crazyradio 2.0
