Cart 0
Long Pins (19+2+4mm)
SKU: 100061450
$2.00
This product is intended to be used together with the Crazyflie 2.x expansion deck system and makes it possible to fit 3 decks. Optimized to fit two decks on top and one deck on the bottom of the Crazyflie 2.x. Perfect to combine with, for example, the Color LED deck.
Specifications
  • Number of positions: 10
  • Spacing: 2mm
  • Pin thickness: 0.5mm
  • Sections: pin 19mm - plastic 2mm - pin 4mm
  • Weight: 0.6g
  • Size (BxHxW): 25x20x2mm
Package contents
  • 4 x Long Pins (19+2+4mm)
Country of origin: China
More from this collection
