Cart 0
Flow breakout board
Flow breakout board
SKU: 114991252
$48.00
This product is discontinued.
The Flow breakout board is used for motion tracking and can easily be connected to any robotics project or other design.
The motion of a surface, usually the ground, is measured and is reported as delta X, delta Y by the optical flow sensor. The Z absolute distance is measured by the Time of Flight ranging sensor. It comes with an Arduino library to easily read the movement data and has a large voltage range for IO and power supply.
The Flow breakout features the VL53L0x ToF sensor and the PMW3901 optical flow sensor.
Features
  • Fast, accurate distance ranging
  • Measures absolute range up to 2m
  • Measures movement in X/Y using optical sensor
  • Power supply and IO 3V - 5V compatible
  • Arduino library for easy usage
  • Minimum range for motion tracking is 80mm
    Package content
    • 1 x Flow breakout
    • 1 x 10 pins male header. Note! Due to a production problem some packages only contain a 4 pins male header.
    Country of origin: China
