Cart 0
Qi wireless charging deck
SKU: 114990116
$30.00
Introduction:
Want to charge your Crazyflie 2.0 without connecting the uUSB cable? Then the Crazyflie 2.0 Qi inductive charging expansion board is a great option. It supports the Qi standard and can be used with the same Qi charger you have for your phone or tablet. It also supports the latest WPC V1.1 specification and is able to supply up to 1A at 5V to the Crazyflie 2.0.
Features
  • Compatible with the Qi standard
  • Automatic detection of expansion board using 1-wire memory
Specifications
  • 1-wire memory for automatic expansion board detection
  • Supports the Qi wireless charging standard (WPC V1.1)
  • Can supply up to 1A at 5V
  • Based on the TI BQ51013B
Mechanical specifications
    • Weight: 5.0g
    • Size (WxHxD): 30x30x5mm
Compatibility
  • Works with the Crazyflie 2.0
Package contents
  • 1 x Qi inductive charging expansion board
Share this Product
More from this collection
